Seal deteriorated on permanently fixed pot
My toilet pot is semented into the floor and rubber seal at the back is deteriorated and must be replaced. Is there a way to do this without destroying the pot?
I've never heard of toilet being cemented to the floor. Are you sure there are no "closet bolts", that may be covered by caps?
See step #3 on this link to know what I am talking about:
In South Africa all is semented but thanks anyway for your response.
@dragonmama take a few good pictures and post those with your question. That will allow us to see what you see. Use this guide Adding images to an existing question for that.
Here is a video that will help. The base of the tank is probably caulked. Use a putty knife to cut the caulking and separate it from the floor. I also would suggest using rubber gloves. Tap or click on the blue link. I hope this helps. Good luck!
Thank You but this is South Africa and I have never seen a bolted toilet pot !! Hee hee. I suppose it can be so much easier to fix !!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 223
1 Comment
Is it leaking? If so, where do you see water?
by Deleted
