Repair guides for Android cell phones manufactured by ALCATEL.
993 Questions View all
Why does my phone say android starting but wont load
my phone keeps say Android starting / starting apps for the past 24hrs . I have done everything even master reset and it still doing the same thing . Can you please help me fix this problem . also the problem start right after metro pcs made an update on it
Score 1
2 Comments:
sounds like the boot loader has become corrupted and is corrupting the OS on restore, you will most likely need to use a computer and the ADB to redo the boot loader and OS.
Good Luck
by
Same thing happened to my metro pcs phone after they updated now phone is just stuck on updating android apps frustrating
by
Add a comment
a factory reset from recovery should fix this. If not flash the stock rom. You can factory reset by holding power and volume up or down(depending on device) then selecting wipe data in recovery mode.
Add a comment
What do I do if my phone is stuck on the Android loading screen?
Press and hold both the “Power” and “Volume Down” buttons. Do this for about 20 seconds or until the device restarts again. This will often clear the memory, and cause the device to start normally.
Add a comment
Instal Nova launcer from Google play and you get new funkcionalnal fast fon... In my case Alcatel 1c was reborn from "android now starting" on main screen.
Add a comment
Add your answer
Dwana will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 3,444
