power window switch works Intermitantely
Power window master switch (driver's side) works Intermitantely for passenger side front and rear windows. The switches on the individual passenger side doors work fine though.
Bob, May want to unwrap/ remove cover on bundled wires between door and door jamb and check for pinched/damaged wires, if all looks good there probably a faulty intermittent switch. You can disassemble switch and clean contacts ( a little tricky, careful of small parts falling out of place sometimes, clean contact areas with, contact cleaner, fine emery sand paper or try pencil eraser) or replace switch. Master power window switch can be found at auto wrecking/recycle yards for a lot less then dealer.
A couple links below to help diagnose pwr win. issues. Good luck.
I found my window switches on eBay, brand new and very reasonably priced.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 978
1 Comment
What's your exact model and year?
by mayer
