Repair guides and support for smaller headsets that rest on top of the ear, also known as supra-aural headphones.
60 Questions View all
Can I solder broken wire back on using the old solder blob?
Hi! My headphones broke on one side. I can see the broken wire inside the ear cup and was wondering if I could just melt the solder that's there and push the wire back in. (after snipping the wire). I've never soldered before and don't know much about electronics.
Here's a picture, you can see where the wire's all broken.
https://postimg.org/image/6fcajabhl/
Add a comment
Chosen Solution
Christian, as Shelton stated could be possible, but if you want a good clean trouble free repair at least get a little flux/rosin cored solder so you will have a clean soldered connection, saves from having to do it twice.
A small amount of rosin core solder can be purchased at most electronics stores and big box stores as well.
Below I will post a tutorial on soldering. Good luck.
https://www.youtube.com/watch?v=Qps9woUG...
Score 4
Add a comment
Should be possible, your picture isn't the clearest though. Before of your temp when soldering you don't want to melt anything. Maybe watch a few basic videos on youtube before you try.
Score 2
Add a comment
Add your answer
Christian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 19
All Time: 3,286
