Why is my laptop overheating?
I was wondering why my laptop is overheating. Is there any way that I can fix this?
Overheating is very common with the Inspiron 9300 if you leave it on for long periods of time, but that does not necessarily mean anything is wrong with your laptop. Your laptop can overheat after using it for just 10 minutes. It can also overheat from watching videos, playing games, or streaming/downloading online content. To reduce this overheating, use the laptop in an air conditioned room and on a stable flat surface like a desk, instead of a cloth or fabric surface like a blanket or pillow. This placement allows for better airflow. If your laptop is getting too hot and shutting down due to overheating, then I would definitely try cleaning the vents with some compressed air to get rid of any dirt buildup. You may need to clean the vents regularly. If cleaning does not help, then you may have an out of date BIOS. To update your BIOS, type in your Service Tag on the Dell Driver & Downloads website to download and install the proper drivers for your computer. Please refer to the troubleshooting page for more information.
The most common cause for laptop overheating is due to the lack of heat transfer, which is because there is no air flow in the vents of the laptop. An accumulation of dust in the vents and fans through the cooling channels might be the main reason, blocking the air flow and therefore causing the laptop to overheat.
Laptop starts overheating
Laptop overheating is most common laptops problem now a days. After a more extended period, this is one of the most prevalent challenges associated with many laptop users. Overheating is one issue that may wreak havoc on your laptop's performance, resulting in system crashes and freezes. Overheating may be a result of their small size or a lack of airflow. In addition, excessive dust might clog air vents, preventing your system from receiving cold air to cool down.
Solution
Cleaning the air vents with a smooth cloth or a keyboard cleaner will cure the overheating problem. Place a piece of filtered cloth over the inhaling vent to avoid further dust blockage. Place it away from the exhaust vent, as this is where the hot air escapes fast.
If it doesn't work, update your system's BIOS, which controls the hardware on your laptop. For heat management, most laptop manufacturers provide an installation file for upgrading BIOS files automatically. When upgrading the BIOS, keep in mind that your laptop must be connected to the power source.
Please check the number of application in taskbar and the consumption of ram and memory, generally if you put pressure on ram it will heat-up the laptop.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 20,594
1 Comment
A laptop might get overheated due to many reasons. Mostly, it occurs when you’re using the laptop for too long or because of dust blocking the laptop's air vents, exhaust port, etc. When your laptop gets overheated, it starts showing symptoms indicating the same, and some of them are:
1. Intermittently restarting or shutting down
2. Startup error messages
3. Slow or no response from the laptop
4. Fans start spinning faster than usual
Even if this problem looks annoying, you can overcome it with simple and quick troubleshooting solutions.
1. Put The Laptop In Sleep Mode
2. Clean The Air Vents And Fans
3. Restart The Laptop
Advacned Solutions
1. Update The OS you have.
2. Run A Hardware Diagnostic Test
by charlie hudson
