The Samsung 5 Megapixel camcorder was released in 2011. It can be submerged in water up to a maximum of 3 meters and dropped from a maximum of 2 meters. It also records video in 1080P.
Why my camcorder won't turn on?
No matter what I do I cannot get the camcorder to turn on. I have charge it for several hours and even check the led on the side is lit when plugged in. The camcorder only has a little over a year and I have used it only a few time, so I don't think is the battery. ANY SUGGESTIONS ???
Add a comment
Since you've tried charging it, you might have to change the screen display according to the trouble page for the device ( Samsung HMX-W200 Troubleshooting ).
Add a comment
Hello,
Since you stated you tried to charge your camcorder without any luck, you may have a faulty USB charging port. But do not worry as you can follow the guide here (Samsung HMX-W200 Troubleshooting).
Add a comment
Add your answer
Antonio Abades Lescano will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 11
All Time: 1,485
