The April 2014 update of the 11" MacBook Air packs refreshed dual-core i5 and i7 Haswell processors and slightly increased battery performance.
100 Questions View all
Laptop is running extremely loud and slow
After dropping my Macbook Air from a small height, I noticed that the computer was running extremely slow and loud. I reset the SMC but that didn't work. I also noticed that my sound wasn't functioning. I went to activity monitor and found my CPU was running extremely high, jumping from 300% CPU sometimes to 1000%. I NEED HELP PLEASE if anyone knows anything. What I might need to replace or do, im not very good at computers. Thanks please help me this is a computer for work
Score 1
1 Comment
Hi there ! How high is "a small height" ? Is the computer damaged on the outside ?
by
Add a comment
1 Answer
Chosen Solution
You computer has an issue with a temperature sensor malfunction - when your computer can't read acceptable data from a temperature sensor, it revs the fans up, and executes a process that takes over the processing power in order to prevent the computer from being exerted, to prevent it from heating up as a safety mechanism. If you open up Activity Monitor, there will likely be a process called "kernel_task" that is taking up all of the processing power. There is a possibility that the drop dislodged a cable, which carries temperature information from another component within your computer. I would open the mac up and check to see if any cables are not connected properly.
Score 2
2 Comments:
Yees the I/O cable was very loose clicked it back in works like a charm now, thanks
Kevin.
by
Hi,
I have the same problem except I'm not sure that it was dropped. I've had a look to see if there is any dislodged cables but haven't been able to find any. Is there anything else that would cause my computer to have same response?
Thanks heaps,
Glenn
by
Add a comment
Add your answer
Kevin Melis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 3,882
