Repair and disassembly guides for GE Microwave ovens.
351 Questions View all
Sparks from upper left vent area
Hello! My GE microwave has recently started to spark and crackle (the noise) behind the vent on the upper left hand side. The sparks are not in the food compartment of the microwave, and the microwave is still heating properly. Any idea what what is wrong and how to fix it? Thanks!
Add a comment
1 Answer
Chosen Solution
Hi,
Sparks usually indicate a loose connection or a breakdown in the insulation of wiring or components allowing the current to arc between two areas of different voltage potential.
Be extremely careful there are high and lethal voltages inside a microwave oven.
I suggest that If you don't know what you are doing that you turn off and unplug the microwave and do not use it until it has been checked out by an expert.
Score 3
2 Comments:
im start my microwave the fuse is spark
by
paano po sya mafifix lagi kacng pumuputok ung fuse
by
Add a comment
Add your answer
smf12311 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 3,317
