Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
Battery Issue, doesn't charge, dc-in becomes hot
done SMC and NVPram resets no change, the dc-in heats up and the battery doesnt charge. What other possible parts could it be if the battery doesnt charge but is detected? could it be a faulty dc-in?
the kernel can run on low cpu if i have it in the smc reset mode (when the fan noise is spinning i presume and the charger light is off)
2 Comments:
Could be battery, DC in or logic board (charging IC circuit, or something else). The kernel task CPU is high, are the fans spinning loudly?
by
^ yes, thats due to running in SMC mode or whatever so its not actually running through the battery, during that stage the cpu load on the kernel is low ~ 5%. Battery replacement is probably what i'm truly after hopefully.
by
Add a comment
1 Answer
Your battery is bad.
Add a comment
Add your answer
James will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 93
