The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 Questions View all
How can I replace my speaker and headphone jack Circuit on F555LA?
In my Asus F555LA laptop both the speaker and headphone jack is not working.I take my laptop to technician and he told me to get it done in 120 dollar but he is not telling me what part he is buying so If you can suggest me the replacement part for speaker and headphone jack I will replace by myself.
Add a comment
Chosen Solution
@harshgatchu , Harsh, I do not know what part or #, the tech, was going to change, Just a thought, maybe try doing these steps before changing parts, try uninstall/reinstall the sound card driver.
Go to device manager and uninstall the sound card driver, open Asus support site, download and install the latest driver there is, when installed reboot your laptop and see if the sound will work after the reboot.
If not working do a system restore, restore you laptop back to an earlier date or time before speakers had quit. Asus audio driver link below. Good luck.
If none of this info. helps, leave your question open.
https://www.asus.com/us/support/Download...
Score 2
Add a comment
There is an issue with the X555LA HDD Board on the laptop and the Realtek Sound Chip is part of that board. New drivers will not fix it because the chip is defective. You will need to replace that board. You can find them on eBay. there are several versions of that board so you must remove the board from you laptop and checking what version you have before ordering it.
Add a comment
Add your answer
Harsh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 804
