Suddenly no power to DVD VCR combo
I have a Sony DVD/VCR SLV-D271P. Everything was fine until I was rewinding the VHS tape & all of a sudden it just went dead. There was a faint blinking on the display panel but it was so faint I couldn't tell what it said. I plugged it in later & no power at all. I checked the fuse near the power & it was fine & I don't see anything looking damaged or not right. Any idea what might be the problem? Thanks for your help.
Score 1
5 Comments
is your device plugged into a power strip? is your power cord detachable from the device. Probably need to get a new device.
by
Tried plugging directly into a few different outlets with same result. Power cord is fixed
by
Did you get it working?
by
I have the same problem & my fuse looks fine
by
@brokendown you have the same problem and have the same make and model?
by
Add a comment
Most Helpful Answer
arch start by following the troubleshooting flowsheet
The components mentioned in the flowsheet are on the same power board as the fuse. If you post a couple of good images, use this guide for that, we can help you point those out.
Score 2
Add a comment
I have no idea what the flow chart is depicting & where to look. I will take some photos of the board around the fuse in the morning . Hopefully you can see the problem or let me know specifically what I need to do. Thanks
Please let me know if you see where the problem may be or what I need to do. Thanks
Score 1
1 Comment:
Did you check your Fuse?
by
Add a comment
Add your answer
arch will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 5,068
