The Dell Latitude E6500 laptop PC was released in August 2008. The Latitude has a 15.4 inch screen with a 500 GB hard drive
21 Questions View all
Bio keep rebooting in my Dell E6500
My Dell E6500 keeps rebooting over and over. This system can not repair disk. Can I install Win 7 again? The laptop wont let me install a new install,I have Install disk from Microsoft. What do I do?
Add a comment
You might try a system restore from safe mode command prompt.
Start the System Restore tool at a command prompt
1.Restart your computer, and then press F8 during the initial startup and select from the options: Safe Mode with a command prompt.
2.Log on to your computer with an administrator account or with an account that has administrator credentials if needed.
3.Type the following command at a command prompt,
%systemroot%\system32\restore\rstrui.exe
and then press ENTER
4.Follow the instructions that appear on the screen to restore your computer to an earlier state.
Try tapping F8 at bootup and select "Last Known Good Configuration" then Enter. If this doesn't work, then you might try system file checker. Go to the safe mode command prompt and type sfc /scannow. Note: space between c and /
You may be asked for the Windows CD, if asked insert it.
Add a comment
Thanks for your response. System restore does not work. It want boot up in safe mode. I try reinstalling Win 7. It stop it. I am sure there must be some liter setting that would correct it.
Add a comment
Add your answer
John Logan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 275
