Why washer stops and gives code "ol"
recently washer began to stop spinning during wash/rinse spin,water drains but clothes somewhat soaked and "ol" code appears,all other operations normal,approx.10-13 yrs old,kenmore elite oasis,total care flex,king size,quiet pak2, model 110.28032701
Score 1
Add a comment
Most Helpful Answer
@eddie9115 just checked your washers manual and "oL" still stands for overload. With your washer this could be caused by a bad bearing in the outer tub, a bad control board as well as a bad motor sensor. Check to see if you can ran the diagnostics mode and see what it tells you. Let us know. Kenmore 110 Diagnostics
Score 2
Add a comment
This answer was originally to another question.
See my previous answer on this:
The washer has ol on it at the end
Score 1
2 Comments:
this answer is for a maytag washer,my question was for a kenmore
by
It's the same answer. OL is an overload code.
by
Add a comment
Add your answer
edward grabowski will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 3,083
