Released April 2013, model numbers GT-N5100 (3G & Wifi), GT-N5110 (Wifi), and GT-N5120 (3G, 4G/LTE & Wifi)
76 Questions View all
I broke the connector where the ribbon cable from the battery attaches
To whomever might be willing to help,
I noticed significant battery drain and purchased a new battery. I have 2 of these devices and have replaced the battery in the other with no problems.
When I detached the cable from the old battery I noticed a black piece from the device (where the battery connects to the pins) broke/chipped off.
After installing the new battery and plugging it in to charge the device turns on, flickers a few times and turn off.
If I put pressure in the general area of the connection in concern it will work fine. However,the second I let off the tablet flickers and/or turns off.
Any suggestions would be greatly appreciated. I'm not sure what the name of the connector is in order to search for a replacement part.
Thanks in advance for your time and help,
B.J.
Add a comment
Chosen Solution
BJ, if connector is still connecting with a little pressure applied but the lock tab broke off, perhaps you could tape connector down and build up a few layers of tape/shim so when device is together the connector has pressure on it to retain connection. Good luck.
Score 1
Add a comment
http://www.ebay.com.au/itm/Genuine-Samsu...
is the part you need it will require some soldering skills to install without damage.
Good luck
Score 1
Add a comment
Add your answer
B J will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 22
All Time: 1,687
