Repair guides and disassembly information for laptops manufactured by ASUS.
Change Laptop Minimum Requirements
how do i change the 'minimum requirements' so I can download my QBs
Add a comment
@suziq sorry but if your computer does not meet the minimum requirements there is no fix. You have to at least tell us what model computer you have, the specs of the one you have and then tell us what requirements you need to download your QB's
1 Comment:
ASUS 'Sonic Master' I have 6 available, but in the 'tech' area it says min require is 950, but I know if changed to 1G then it will download no prob, I just don't know how to change the MR. (my tech guy is on vaca) Your help is muchly appreciated. thank you
by
Add a comment
Yep, he's right. The minimum specs is the least amount of hardware capable of running an application, in simple terms. I guess if you want to change minimum spec you will have to buy new hardware, or a new laptop.
P.S. To build a new computer is to save hundreds over a pre-built computer.
Add a comment
Add your answer
SamWalker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 70
