The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
273 Questions View all
Can I use a nail file?
Can I use a nail file to clean the corrosion in the game card slot or do I have to use a Q-Tip with rubbing alcohol on it?
3 Comments
What exactly are you cleaning?
by
The game card slot.
by
Never use a nail file, you'll damage the components even more.
by
Add a comment
1 Answer
Chosen Solution
Don't use a nail file to clean corrosion, you will damage the components on the board.
Use a Q-tip or toothbrush and 95%+ isopropyl (rubbing alcohol)
Score 4
4 Comments:
I have 70% isopropyl, is that ok? Also, I am cleaning the slot where you put the games in.
by
It's also 30% water so make sure it's dried out before testing.
by
ok, how do i dry it out?
by
You leave it to evaporate. Personally I use 99% isopropyl to bath liquid damaged boards after an ultrasonic clean. This helps quicken the drying process since it evaporates quicker than my ultrasonic cleaning solution. Usually check them a day after this to completely dry
by
Add a comment
Add your answer
kdcao1 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 89
