Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
Power - on Failure (mostly)
IMAC 20'' 5.1 late 2006
Hallo,
I have a "funny" failure with my 20'' IMAC.
First - month ago - he didn't want do start with the first try, but he came...
But it was getting poorer - and after a longer time and not using he wouldn't start.
The power-supply was not ok. One capacitator war blown. I changed it.
I changed the big 150mf 420v too.
First: no succes. LED01 is blinking.
The ventilator "tries to turn". (neerly not to see, so little)
But: if the IMAC ist connected to 220V and I seperate the connection that comes from the power-supply on the mainboard and put it together after some secondes, LED 01 ist ok and the IMAC works.
Anny idea to fix it?
Thanks
cpg
Add a comment
1 Answer
Chosen Solution
Your diagnostic LED indicates you still have a PSU power supply issue. Replace or repair it.
here's how:
iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement
Score 3
Add a comment
Add your answer
peter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 129
