I can't play any video games?
After the system is on and the game is in, it can't read the game disk. I took it apart because the drawer was getting stuck once in a while.
Hello,
this could be caused by a broken disk drive, you can find replacement parts. and how to fix.
I will have some links for you and I hope they help you.
Drive replacement guide - Xbox 360 Optical Drive Replacement
Drive replacement part - Xbox 360 Jasper Motherboard and Paired Optical Drive
I hope all this helps.
Thanks,
Keegan
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 76
Hello gregtweintraub!
It seems that the DVD DRIVE might be broken on your XBOX360.
Does the DVD DRIVE make any sounds when you put in a game?
If yes then there might be a problem with the LASER.
If no then your DVD DRIVE itself must be replaced.
Are you sure you put it back together correctly?
Al cables are connected including the RIBBON CABLE?
Good Luck!
by MrMasterboard
