The fourth version of Sony's famous Walkman cassette player, the WM-4 was introduced in 1983.
10 Questions View all
My WM-4 Sony Walkman wont spin/turn but the battery indicator is on
I own a Sony WM-4 Walkman and it has new batteries yet it does not spin or turn and the indicator light is on and there are no internal or external nois but some static from the audio A and B output.
Any help apperaciated
Joseph
Score 1
Add a comment
Chosen Solution
Found it the motor is Dead connected a 6v dc powersuply to the motor and nothing happened
Add a comment
Most Helpful Answer
Joseph Protheoe you did not tell us if it worked before you changed the batteries. You want to make sure that the battery contacts are not corroded and make proper contact. If that checks out you want to disassemble it and take a look at the belt. Here is a teardown that will help you get into it. check the belt as well as the board for anything obviously damaged. Let us know what you find and it might help if you post some images with your question. For that use this guide. It will allow us to see what you see.
Sony Walkman WM-4 Image
Guide
Sony Walkman WM-4 Teardown
Difficulty:
Moderate
iFixit Image
Guide
Adding images to an existing question
Difficulty:
Very easy
2 - 5 minutes
Score 2
Add a comment
Add your answer
Joseph Protheoe will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 29
All Time: 2,704
