Model: Dell Vostro 1440/1450/1540/1550 Released Date: 2009
15 Questions View all
My laptop shutdown in every 30 to 40 minutes
my laptop shutdown in every 30 to 40 minutes and when i try to start again blue screen apear and system restart after trying 3 or 5 times its start
1 Comment
It could be a thermal issue with the CPU, the laptop will shut down if it detects overheat problems. It also could indicate that the thermal detection has gotten too sensitive which would indicate a bad mother board.
by
Add a comment
1 Answer
Most Helpful Answer
@valvi31, nitin , Could be overheating. Use the link below, a guide to dismantle your laptop so you can clean your computer inside. The fans and board may have accumulated a lot of dust, not allowing heat to dissipate properly causing it to over heat and shut down, the 3rd and 4th link will show how to clean. Good luck.
vostro-1550servicemanual.pdf
https://www.youtube.com/watch?v=c8HU06L4...
https://www.youtube.com/watch?v=9MAkHA-f...
https://www.youtube.com/watch?v=T0BQ6YUF...
Score 1
Add a comment
Add your answer
nitin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 312
