Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
180 Questions View all
wont start and insturment cluster says van is in reverse
van was running fine went to place it in park and turned it off when i went to start it again there was nothing noticed then that the indicator for what gear it was in was reverse
1 Comment
I had it to a shop they told me the neutral switch was located in the transmission housing and rather expensive to fix
by
Add a comment
Chosen Solution
its probably the safety neutral switch out of adjustment or defective it should be located on steering column down by floor board
Score 1
Add a comment
It likely won't let you start the engine unless your in park. It may say that your in reverse because the sensor or switch has broke or possibly moved. I would try shifting through all of the gears (neutral, D2 D3 D if you have them) before taking it to a repair shop.
Score 1
Add a comment
Add your answer
bernard gaudet will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 853
