Released in 2010 and 2011, the G73 is a series of gaming laptops from Asus. Model numbers include G73JH, G73JW, and G73SW. All versions use an Intel Core processor and dedicated graphics card.
17 Questions View all
Asus G73JH Memory Specifications and Requirements
Three slots were accessible and empty when I tried to boot it up. The last slot (which needs near-complete disassembly of the laptop to access) had a 2GB chip.
The laptop failed to POST BIOS - I got steady LED lights and a battery light if a battery was present. Wasn't sure if this 2GB was defective.
Pop in two more matched 2GB chips (matched to each other but not necessarily the lone, inaccessible third 2GB chip) - laptop posts and recognizes all three 2GB chips, giving me 6GB.
Did I need to populate the accessible bank of RAM slots first before populating the "split bank" (one slot on the underside, one slot on the topside).
Is 32GB possible on this thing (4x8GB)?
Add a comment
1 Answer
If the motherboard was designed in such a way, it would require at least one slot from each bank to be loaded. Laptop motherboards aren't standardized like most desktops, and that allows for OEMs to take creative liberty in their designs.
If that one 2GB card was defective, it would still fail to post with the other cards in. Again, it may just be a flawed design.
The maximum memory supported by your laptop's motherboard is 8GB DDR3 @ 1333Mhz, as per ASUS technical specifications. 32GB of RAM is not possible on this machine.
Add a comment
Add your answer
lkvee will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 20
All Time: 1,430
