Cracked screen, unresponsive touch
So yeah, i accidently damaged my android device, which ended up on the screen cracking and it doesn't respond well to touch.
I'm uncertain on what do i exactly need to buy in order to fix it.
Is it this? http://www.ebay.com/itm/Asus-ZenPad-10-Z...
Score 4
1 Comment
The zenpad 10 touch screen is glued to the lcd, much like an iphone...You will more than likely end up ruining the lcd if you try to change just the touch portion. It is better to buy the whole assembly and replace the lcd at the same time. I say this from experience...doing one right now.
by
Add a comment
Chosen Solution
If your LCD is not functioning then yes this is what you need but if you still have a picture that's right in all parts of the screen and the touch function is all that's wrong then you only need the digitizer similar to this
http://www.ebay.ca/itm/Touch-Screen-Digi...
Hope this helps
BTW you can find tutorials if needed on youtube on how to replace both the digitizer or the full assembly . If you don't mind paying the extra the full display is easier to replace than just the digitizer
Score 3
3 Comments:
Thank you very much for your answer, Jimfixer. After watching a few videos, it seemed to require special tools and being complicated, so i might just buy the whole thing. Thanks!
by
Hi I have the same problem, would you mind sharing a link of the videos you've watched please? I can't find any on YouTube with regards to my tablet (zenpad 10). Thanks in advance
by
Can you help share some good videos? The one or two ive found are lacking detail. I'm trying to replace the digitiser on a z300m
by
Add a comment
Hi I have just replaced the whole screen and digitiser and it's not responding to the touch any ideas thanks pat
2 Comments:
have u solved? i have the same issue!
by
Hello! The same problem - replaced broken display module ant touch with digitizer doesn't work at all. Anyone solved?
by
Add a comment
Hi is it possible to just replace the outer glass touch screen ?
My screen is cracked lcd is good and the whole assembly is pretty expensive but I don’t seem to find any videos teaching how to do it ...
I live in EU
2 Comments:
Virtually impossible. The touch is glued to the lcd. The only real way is a special machine with a thin heated wire that slides between the two. Swapping the whole assembly is pretty easy and the assembly runs about 50 US.
by
Yeah I figured it out
Problem is to buy from eu it gets expensive with shipping
Idk why but my tablet is z300m so it’s more expensive for this model than to other z300xx
by
Add a comment
I have the same issue with the model. If anyone can point me to the direction of a video (with audio explanation) on how to replace it that would be great.
Add a comment
If you've replaced the whole assembly and get no touch response. Try rebooting device by holding Volume down and Power and then choosing reboot in menu.
Add a comment
Add your answer
Bernardo João will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 11
All Time: 8,681
