The Epson WF-2540 is an all-in-one color inkjet printer. It features a 2.5-inch LCD touchscreen and four individual ink cartridges.
showing paper jam message
My epson wf 2540 is showing a paper jam message and there isnt a jam
Score 1
Add a comment
1 Answer
Try the following methods to fix paper jam error:
  • Unplug your printer while it is on. Leave it for approx 30 min. Plug it back on. Sometimes this might resolve the issue.
  • Sometimes there is might be something probably inside your printer in some positions which blocks the paper sensor along the paper path in that positioned you can't see.
  • Remove the toner cartridge( if you are using) and shake your printer up and downside gently and carefully.Remove all ink cartridges and reinstall them one at time. Move the carriage over to far left and back in position. Re-position the encoder strip of print head carriage.
  • Ensure that your paper tray must not be over filled. Verify that papers are not packed too much tightlyin paper tray.
I hope with all these tips you might resolve your issue. If still it shows paper jam error that means there is hardware failure. But don't worry check Epson Workforce Wf-2540 Manual for diagnosing and troubleshooting your printer.
Add a comment
Add your answer
Kirk Bell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 6,804
