Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
iSight "camera not connected"
Having followed the excellent guide to install dual HDD in my 24" iMac, everything works except when I try to use my internal iSight camera it says: "camera not connected."
It IS listed as a USB device under system profiler.
I have tried:
  • Reset PRAM
  • Disable SIP
Any ideas before I disassemble and check cables etc.?
2 Comments
Thanks for your quick answer. I'll do this next week and report back.
by
OK, so pulled it apart and had a look, couldn't find anything disconnected...
Gave iSight connector a wiggle...
iSight cable disappears behind tape, can anyone tell me where it connects to logic board?
System profile still shows "built-in iSight", with serial number, current available etc. But no apps can activate it...
by
Add a comment
Chosen Solution
OK, so that was weird... (*See my comments above - pulling it apart and wiggling all the connectors didn't work, nor for that matter did SMC reset)....
However, some weeks later I came back for one last try:
  • I tried to boot in Safe mode... wouldn't boot..showed a circle with a line across it.... then shut itself down.
  • Powered it up again... opened FaceTime... "no camera connected." Darn it.
  • I booted up my old Windows XP installation in VirtualBox, and since iSight was listed in USB devices, I went to "devices>USB>iSight" and tried to attach it to VirtualBox. It wouldn't, Windows acted as if it didn't exist. so shutdown VirtualBox.
Then lo and behold.... opened up Photo Booth and saw my surprised reflection... and a little green light. Then I'm fairly sure I heard/imagined a hallelujah chorus.
Its a bit blurry... might have to pull it apart and give camera a wiggle... or might not risk it....
But I share this in case someone on the internet has the same weird problem that I did.
Add a comment
Most Helpful Answer
No, proceed straight into disassemble the machine and check the cables.
Score 2
Add a comment
Add your answer
Andrew Vines will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 357
