The Samsung Galaxy S5 NEO (SM-G903F) has a 5.1 inch Super AMOLED display with Full HD resolution. It's front and back cameras clock in at 5 megapixels and 16 megapixels respectively.
21 Questions View all
Media volume problem due to water damage
I accidentally dropped my phone into a dish with quite a bit of liquid, and only the top of my phone got wet.
After that I found out there is a problem with the media volume, I just can't play music without the earphone or talk on the phone without turning on the speakerphone, I can still hear the notification sound of Whatsaap message though
And as you can see in the photo below, the media volume is in red
Please help thanks!
http://tinypic.com/r/t4wmtz/9
http://tinypic.com/r/4h45eh/9
Score 2
1 Comment
See instead of doing all that work what I did which worked is I took out the battery and put the phone and battery in rice overnight then my volume for media worked again. It is less complicated and you don't need to use slot of money
by
Add a comment
1 Answer
Chosen Solution
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that describes the process.
Electronics Water Damage
You may have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the Ifixit guide for replacing the screen in your phone. It is handy because it shows how to dis-assemble the phone.
Samsung Galaxy S5 Neo Display Replacement
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 4
2 Comments:
Instead of doing all that Work all you have to do is take out the battery and put the battery and the phone in rice that's how it fixed my media volume but do it overnight and it's less complicated.
by
Hi @ Victoria L,
You may be interested to know this.
Don't Put Your Device in Rice. Here's Why...
by
Add a comment
Add your answer
Christine Chu will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 48
All Time: 13,042
