ms surface pro4 keyboard not functioning
my ms surface pro4 off-screen keyboard loses contact or does not function from time to time. sometimes it works, sometimes it doesn't.
1 Comment
I think Microsoft should cover that under warranty as it should not do that.
I know that my cover loses connection if used near 130° or more.
But if I use it as intended it works fine.
by
Add a comment
Chosen Solution
it sounds like the keyboard cable has dislodged a little. this is actually very common with this computer. the solution most of the time is to take the laptop apart very carefully since there is a cable that connects the bottom of the laptop to the logic board, and reseat the keyboard cable. I just had to fix this exact issue last week. I really hope that is what is wrong with your computer and that you are able to get it working correctly soon.
Score 2
2 Comments:
Thanks. This worked on the first few instances it happened but not recently. I fixed the problem by detaching the type cover and doing a suggested solution by surface.com: cleaning the tips of the 4 connectors with a cotton swab and alcohol. I hope I don't have to do this all the time.
by
it is best to err on the side of caution. so i would do that solution again even though i know that it is a pain. but i believe that it is less painful then having to pay $100 just for someone to try to figure out whats wrong with it in the first place. also i probably should have mentioned this earlier but make sure all of your drivers are up to date
by
Add a comment
well done Jesse - my surface 3 started the MS game, will I, won’t I, work today, finally error message ‘cannot connect USB device and the type cover stopped working altogether.
I looked at other solutions first, dismantling the tablet seemed too hard, then I found your suggestion. I cleaned both the little contact pins and the contacts on the tablet side with isopropyl - worked perfectly ever since - many thanks, I had even considered buying a new one - you saved me megabucks
Tony
Add a comment
Add your answer
Jessie Ponce will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 226
