How to get to bulb and replace it
how do i open the lends to get to the bulb and how do it remove the bulb
Hi,
I realize that the Ozark trail OT100L is not the model of the torch you are asking about but it may be that it is put together the same way as yours as they both use LEDs, not incandescent bulbs as the source of illumination
Here is a link, hopefully it will be of some help
Had a ? I have the 750L rechargeable aside from vice grips and hammer how do you take it apart to troubleshoot. Full charge but refuses to turn on
I have tried to get battery cover off including using adjustable wrench and hitting the cover on the side it will not come off I need to change batteries and it won’t open any ideas?
Hi @eobfish,
I don't know the torch but looking at the images in the link shown in the answer once the lens cap has been screwed off and the LED fitting prised out then the battery holder can be pulled back a bit and then has to also be prised out of the cover.
I think that nothing comes out of the back end of the torch. Everything is done at the front.
Just my take on this
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 46
All Time: 12,541
