A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
Battery won't charge, replaced the battery and charging connector
I really could use some help. I have two Samsung Galaxy Note 10.1 tablets from customers that won't charge. Sometimes it gives a red cross through the battery and sometimes the icon is normal but the battery still does not charge.
On one of the tablets I already replaced the battery and the charging dock cable. But sadly it still does not charge. I also tried different USB cables and charging adapters both original and third party.
Both tablets have android version 4.2.2 on them. Is there possibly a problem with the software and how can I (re)calibrate the battery?
PLEASE HELP!!
Score 1
1 Comment:
I also replaced battery, charging port and charging cable . It doesn't even recognize that anything is plugged in. The new battery I put in at least let me boot up and all works great , but when this battery runs out of juice I'm doomed...
by
Add a comment
1 Answer
Just found this----way late for your purposes. May be that the Charging IC (Integrated Circuit) on the motherboard needs to be replaced.
Add a comment
Add your answer
Koen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 150
