A 12.2-inch "prosumer" tablet released in February 2014. Powered by a custom version of Android 4.4 KitKat.
40 Questions View all
My tablet will not turn on after some DIY repairs
My tablet had screen flickering issues and after some research, I decided to unplug the battery and reconnect. Little did I know that the battery connector on the motherboard breaks off super easy. So then my only option was to re-solder the pins to the connectors, which I did but it still won't turn on. Some of the connectors won't accept the solder so I super-glued them, but still nothing. Any advice would be great, I called UbreakIfix and they said the base cost of repair would be over $300, which I cannot afford. Should I call Samsung? Thank you for any help.
Add a comment
1 Answer
Chosen Solution
luke.puller , Very big mistake using the super glue for trying to make a electrical connection as it could do the opposite and become an isolator. Probably best to just take it into a good local computer/cell phone repair shop and have them take a look and estimate repair. The whole board can be purchased for $120.00 and can probably be found used for a lot less if need be. Good luck.
http://www.ebay.com/itm/OEM-Samsung-Gala...
Score 1
Add a comment
Add your answer
luke.puller will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 129
