The Motorola Moto G (2nd Generation), also known as the Moto G2, is the 2014 successor to the Moto G. The Moto G2 is equipped with a 5-inch 720p display and a Qualcomm Snapdragon 400 processor. Model numbers XT1045, XT1040, XT1039, XT1069, XT1068, and XT1064.
78 Questions View all
My phone is stuck at 1% not charging
During the day I was using my phone I was running low on battery. I couldn't get to a charger in time because of shopping and what not. As I got home, I plugged my charger in and it displayed the white screen with the battery showing the percentage which was at 0%. I waited for a couple of minutes hoping that my phone would turn on but, it didn't. It was still stuck at 0%. I searched up some videos, guides, tutorials and I managed to only get to open my phone only for it to have the charge stuck at 1% and not charging.
4 Comments
i can't charge my phone i wonder is it the battery
by
Charging is stuck at 9% and despite charging it for 2 to 3 hrs it remains the same. What should I do?
by
Same issue stuck on 9% all day this phone is brand new 😒
by
Same mines still stuck on 1
by
Add a comment
Most Helpful Answer
Multiple issues cause this failure. in essence, your device acknowledges the charger, but something is preventing the circuit from charging the battery. Symptoms in likely order are
1) battery: - The battery is not accepting a charge, or draining faster than your charger will pump the life into it. To fix this, replace the battery.
2) Charging Block/Cord: - Your charging apparatus is recognized as a circuit, however, not providing adequate charge to the device. to fix this, replace your Charger. (Block and cable both to be sure) I would never suggest using a charger under 5V/1A output.
3) Charging port.: - The charge port had multiple pins. some for charging, some for data. if one of these pins is failing to connect, it will not charge the device properly, and you can get a slew of different symptoms. the one you are experiencing being one of them. to fix this, replace the charge port. this is a solder job, and i would not suggest doing the repair on your own, unless you have a large amount of experience working with solder.
4) Motherboard: - The circuit that processes the current may be failing on the motherboard. without a developed skillset, it is unrepairable, and replacing the motherboard usually gets more expensive than just buying the phone itself. id look into professionals to do any repairs on the board itself, as micro components are tedious, and painstaking. requiring a microscope, and a concentrated hot air gun.
I hope these helped your diagnosis. Regards.
Score 1
Add a comment
Seems like you need a battery replacement. Something must be faulty with your battery and it isnt getting a charge.
Add a comment
Try taking the sim out. Turn on to bootloader. Then recovery. Then fastboot. leave it plugged in. My $@$* was like that for a couple of weeks and had done this before. Currently, just got it to take a charge.
Add a comment
Add your answer
MapleSniper 123 will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 91
All Time: 10,611
