wont go through full cycle
Washer works fine until it has 19 minutes left. Then the timer won't go down any further
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer may stop mid-cycle. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
Cause 2
Door Lock Motor and Switch Assembly
The door lock secures the washer door shut during operation. Once the washer door is closed, the washer can begin operating. If the washer door is not latched shut, the door switch prevents the washer from operating. If the door lock is defective, the washer may stop mid cycle. The door lock can fail either mechanically or electrically. Inspect the door lock for damage. If the door lock is damaged or does not latch properly, replace it. To determine if the door lock has failed electrically, consult your washer’s diagram and use a multimeter to test each of the door lock switches for continuity. If one of the switches does not have continuity, replace the switch.
Cause 3
Water Inlet Valve
During the rinse cycle, the water inlet valve opens to allow water to enter the wash tub. If the water inlet valve fails, the washer will continue waiting for the water to enter the washer, causing it to stop mid-cycle. To determine if the water inlet valve is defective, use a multimeter to test it for continuity. If the water inlet valve does not have continuity, replace it.
I have a Neptune model that keeps stopping
@counsell587 , Scott Counsell , You do not state your model # so I will Post some general idea's. Are you getting any error codes on display. 1st link below error codes and possible cause/solution. Link 2 and 3 is how to enter diagnostic mode. By possibly retrieving a code could tell you why it is stalling at 19 min. mark. Good luck.
http://appliancediagnostic.com/Washer-Re...
We are having same issue, however, we do not have a place for a "code" to show up to indicate an error. Our model # is MVWX655DW1. Called Maytag and of course they have no techs on hand that can help you trouble shoot. Thanks for any and all help!
Thanks it is my water sensor by pass it I took my water hose fill my machine with water and then it started by itself and went threw the whole 5 cycles..
Ours was the control board
Ours was the control panel
How did you determine control board I think I have the same issue, very noisy clicking sound ( like a computer ) when cycle stops around 19 minutes and water does not exist machine
I am also interested in "how did you determine it was the control board" I replaced the RPS sensor - ran one load successfully but the next one stopped mid cycle. I hate to spend more just guessing and hoping . thanks
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 78
All Time: 39,773
2 Comments
@counsell587 let us know your exact model number.
by oldturkey03
I'm also having similar problem except my washer is the MVWB300WQ0 model it goes until 26 mins then jumps straight to 4. Code OL appears even when the washer is empty with no clothes
by Kayla Bailey
