Can I use the pump from a 700r4 in 4l60e
can i use the pump from a 700r4 in a 4l60e
It depends. If they have the same part number, Yes. If not if they look the same in every way shape and form you can give it a shot. There is the chance that you break something and then your screwed but if everything looks the same besides model number you can give it a shot if you want to take the risk.
Hope this helps! Good luck fixing!
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 19
All Time: 953
Dont have money right now to replace New and had a pump from a 700r4. But the pump go's down so far then stops will not seat all the way down any ideas?
by John Doe
