HP Deskjet 3530 All-in-One Printer Series - Regulatory Model Number: SNPRH-1102
7 Questions View all
Why does printer continue to jam after removing jammed paper?
Printer continues to jam when trying to print. This occurs after clearing jammed paper. Paper does not advance after being pulled into printer. Does not feed under rollers before ink cartridges.
Add a comment
1 Answer
Most Helpful Answer
A very common issue with all printers is the rubber pinch rollers loose their grip from the paper dust so I would start off by carefully cleaning the rollers with cotton swabs (Q-Tips) and isopropyl alcohol. You may want to use a small paint brush to scrub down the parts and a can of can'ed air to blow the dust away. Just be careful you don't snag a part with the brush pulling it off.
Start there and let us know how it goes.
Score 2
Add a comment
Add your answer
jeansheehy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 289
