Service engine light code 45
Service code 45
Service engine light came on observed 1 reader says computer going bad where is it located
Add a comment
1 Answer
Chosen Solution
Bill Duckworth , The code 45 for rich exhaust is most likely caused by one or more of the following:
a. fuel pressure - system will go rich, if pressure is too high. The ECM can compensate for some increase. However, if it gets too high, a code 45 will be set.
b. Leaking injector or rich injector - perform an injector balance test. Check for fuel contamination in the oil..
HEI shielding - an open ground ckt 453 may result in EMI, will result in induced electrical "noise". The ECM looks at this noise as reference pulses. The additional pulses result in a higher than actual engine speed signal. The ECM then delivers too much fuel, causing the system to go rich. The engine tachometer will, also, show higher than actual engine speed, which can help in diagnosing this problem.
d. Canister purge - check for fuel saturation. If full of fuel, check canister control and hoses.
e. MAP sensor - an output that causes the ECM to sense a higher than normal manifold pressure (low vacuum) can cause the system to go rich. Disconnecting the MAP sensor will allow the ECM to set a fixed value for the MAP sensor. Replace the sensor if the rich condition goes away when the sensor is disconnected.
f. TPS - an intermittent TPS output will cause the system to go rich, due to a false indication of the engine accelerating.
g. O2 sensor contamination - Inspect oxygen sensor for silicone contamination from coolant, lead contamination from fuel or improper RTV sealant. Silicone contamination will be indicated by a Code 45 and lean drivability conditions and a powdery white deposit on the sensor. The ECM will then reduce the amount of fuel delivered to the engine causing a severe surge drivability problem.
Check for a leaking fuel pressure regulator by checking the vacuum line to the regulator. If there is fuel in the vacuum line, replace the regulator.
Info. copy paste from link below. Good luck.
http://www.misterfixit.com/code45.htm
Score 1
Add a comment
Add your answer
Bill Duckworth will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 24
All Time: 4,433
