Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
MacBook Pro Sounds not working
I have a MacBook Pro. Everything works except the chime and the internal speakers.
Add a comment
Most Helpful Answer
Look in the audio port and see if there is a red light on.
Score 2
1 Comment:
is the audio port same as headphones port? no there is no light on audio port.
thank you for your help , what to check next?
by
Add a comment
Check to make sure your volume isnt off first, because thats always a silly mistake. Next go to system preferences then to sound and make sure the output is set to the Build-in speakers. If it isnt, set it to be built in speakers.
Hope this helps and good luck fixing!
Score 1
3 Comments:
I have tried all that but the same issue
by
Somebody in NYC said there is a inductor that is blown on the audio and power rail ,my problem is I don't know how to locate it bec I don't have the schematic..
by
It's 820-2936 B
by
Add a comment
If there is no start chime, try a PRAM reset (keep the keys “alt cmd P R” pressed until it is starting two more times). If you can hear the start chime now, the headphone jack is probably the culprit. Do headphones work? What output devices are listed in the sound system preferences? If the only one is i.e. the digital output, I guess the jack does not switch the output options.
Add a comment
Hello, I had this problem once before. Here’s how to fix it (at least, that’s how it fixed for me.)
step: 1: go to system preferences, locate the tick-box for “sticky keys”( I don’t remember what tab it is under, sorry.) toggle it on, then toggle it off again.
step: 2: enjoy having your internal speakers work again!
note: this is how mine got fixed, may not work for everybody.
Add a comment
Add your answer
Solomon Zamora will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 20
All Time: 520
