Pop up flash spring replacement
On my EOS Digital xt, I am having a difficult time replacing the spring for the pop up flash. A diagram would be helpful.
I had the same problem and finally got it fixed last night.
The spring goes in with the slightly longer end with one bend first. This goes in a slot toward the bottom and has to hook around something inside. I put it in with the flash closed but kept checking until I had that end right. To do this I opened the flash while holding the spring until I finally had it so that end of the spring was staying in the slot and not visible. This took several tries. Then I carefully closed the flash while holding the spring and re-attached the top end. For a LONG time I had been trying to just attach this end by turning it counterclockwise and of course it wouldn't stay in the hole. It has to be turned clockwise (going over the top of the spring) and then into it's hole.
I hope my answer is helpful to others with this problem.
Any chance you have a picture of this? I can't find it online anywhere.
thankyou very very much. I had the exact same issues and had been trying endlessly only turning it counterclockwise!
@Amanda Swant
Sorry Amanda but I just saw this now.
It was my sister's camera and I didn't take any photos.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 1,238
