The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
142 Questions View all
Water Damage, Screen Dark and Flickering.
A family member spilled water on this macbook air a few months back and gave it to me yesterday. They had turned it on, and while it does boot up and the keyboard and trackpad work, the screen is at a very low brightness, as if the backlight is broken, and will occasionally flicker between brightness settings, but always staying very, very dim.
Add a comment
1 Answer
Most Helpful Answer
Michael Gorman , Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the Macbook. You really should take care of the corrosion that is happening inside the device from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the device to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the Mac and see if further damage has to be addressed. 3rd link is to more disassembly guides if needed. Good luck.
MacBook Air 11" Early 2015 Teardown
Electronics Water Damage
Score 4
3 Comments:
Alright. I haven't charged the laptop since I got it, and I don't know if the family member that gave it to me has been trying to charge it. Thanks for the advice.
by
Michael Gorman, Welcome, Good luck with you computer, thanks for posting back.
by
No problem. I will attempt to keep you updated.
by
Add a comment
Add your answer
Michael Gorman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 3,610
