A portable wireless bluetooth speaker introduced in 2013 by Beats by Dr. Dre.
26 Questions View all
black beats pill xl - missing rubber flap
I have a BEATS PILL XL - I see it is missing the black rubber flap that covers USB/connectors on top of unit which has serial # on the underside of the flap that I need in order to return unit for recall refund. Ugh!! Can someone help? Can I get areplacement flap? Is serial # anywhere else on the unit? I no longer have the box.
Score 1
Add a comment
1 Answer
Most Helpful Answer
@mamamaddog , Chris , Rubber flap/port cover does not seem to be available. You may have to disassemble and look inside for serial# tag. Check out the disassembly link below it appears the are a few tags inside the Beats Pill XL which may very well have the serial # on them. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Beats Pill XL Motherboard Replacement
Score 2
6 Comments:
I need to know for sure that the serial number is in fact inside the unit before I make any effort to open it. Does anyone know? How many alpha & numeric digits are contained in the serial number? Looks like there might be a couple of stickers in there when the unit is opened. Thanks for the help.
by
Did u find it
by
Hi, I have the same problem. Were you able to find it?
by
Did u find it
by
I found one at a flee market today. Same problem, missing rubber flap and therefore without serial number.
I opened it up and checked all the boards (the two button boards and the main board with the ports). No serial number to be found internally. 😔
by
Show 1 more comment
Add a comment
Add your answer
chris will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,411
