Motorola released the Droid Turbo 2 in late October 2015. Model number XT1585.
What screwdriver does the inside take?
I have the iPhone screwdriver but that doesn't work
1 Comment
that's a pretty vague question.
do you have a picture of what youre talking about?
by
Add a comment
1 Answer
Most Helpful Answer
@turtlj ,Turtl Johnson, From the partial disassembly link below, these are the screw types mentioned.
17 screws from the board using a T3 bit on your screw driver. Or, use a T4 bit if the screw is slightly stripped.
4 silver screws on the top and bottom are 4.0mm Phillips #00, and the 13 black screws around the sides are 3.0mm Phillips #00.
Using a T3 bit on your screw driver, remove the two 4.0mm screws from the metal bracket.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Motorola Droid Turbo 2 Rear-Facing Camera Replacement
Score 2
Add a comment
Add your answer
Turtl Johnson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 833
