How do I set the idle speed
how do I set the idle speed
Update (04/02/2017)
it is a Kodiak 700 yamaha
I don't know your model, but assuming it uses a regular valve, follow the throttle line to the engine. Where it ends, it should be attached to a lever that gives it gas. At that point, there should be a screw or nut to turn that adjusts the pull on the lever. Tighten it to increase, and loosen to decrease gas. You can do this while the engine is running to spectate adjustment. Good luck!
Donna Cranek , You did not state your exact model and engine so I will post some what generic info. that may help. Use the links below to see how to adjust the idle speed. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/659983...
https://www.youtube.com/watch?v=A1vRMERs...
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 2,669
1 Comment
Donna Cranek what model is your ATV?
by oldturkey03
