The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
127 Questions View all
Broke LT and RT holders how do I replace it?
I have provided two pictures, the blue controller is the one that I'm trying to fix. The dissasembled controller is the one I'm using for the RT and LT.
I want to remove the Trigger holder from the controller but don't know how to do it.
It's the metal piece holding the Triggers.
I need help guys.
Score 3
1 Comment
Hello, my RT button on my Xbox One controller is not working correctly. When I get on NFS the car drives by its self.
by
Add a comment
Most Helpful Answer
https://www.youtube.com/watch?v=NZp8Rcik...
Score 2
1 Comment:
Thanks for that
by
Add a comment
Hello @imzai,
There is no photos as I can see, did they upload correctly?
Well, I provided a few IFixIt links that may help
Xbox One Wireless Controller Trigger Rumble Motor Replacement
Xbox One Wireless Controller Buttons Replacement
I hope these help!
Thanks,
Keegan
Xbox One Wireless Controller Model 1537 Trigger Rumble Motors Image
Guide
Difficulty:
Difficult
15 - 20 minutes
Xbox One Wireless Controller Model 1537 Buttons Image
Guide
Difficulty:
Difficult
30 minutes - 1 hour
Score 1
3 Comments:
I have edited my post, I've uploaded the pictures, what I mean to to remove from dissasembled controller is the metal stick holding the triggers.
by
Okay I see, so if you look back in to the link Xbox One Wireless Controller Trigger Rumble Motor Replacement it shows how to remove the moters. So, I think by the look of the photos its soldered to the board. Can you confirm this?
by
Add a comment
You have to press the small part of the metall pin then it comes out on the other side where you can grab it with pliers / tongs / nippers and pull it out gently.
You have to be very carefull, else you destroy the trigger or the frame.
Add a comment
I need a LT trigger spring
Add a comment
How to take this off lt button
1 Comment:
Same here, my rigger holder is broken too
by
Add a comment
My left triggers has came out of the socket please help
Add a comment
Add your answer
J Angel will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 96
All Time: 29,312
