Released in 2013; Android operating system; 8 inch screen size
5 Questions View all
wont charge but it should
This tablet is not charging.
-when i plug in charger it can comunicate with PC
-when i test it with multimeter it shows 4.35V connected to PC , 4.55V connected to WALL. ( on battery it says input : 4.35V)
-i tried to change battery and same thing
-when battery is charged , phone works but battery % are droping and than it turn off...when i try it with charger plugged inm than it is dropping even faster
-i tried to leave it charging for hours and nothing changed...
-sometims i can turn on tablet and it shows battery is charged to some %, but it starts to drop really fast again
-i tried hard reset
-charging port looks in perfect condition, and when multimeter shows it is ok i dont think if i replace it, anything will change
-of course i tried multiple cables
-when it is plugged in and i want to turn it on, it just show battery lvl for second and turn off... i need to plug it off to turn it on
Add a comment
1 Answer
Is the charging port soldered to the motherboard? are the solder points visable/available to test with a multimeter?
1 Comment:
yes it is and as i said before it looks in perfect condition from inside and outside. it comunicate with PC also
by
Add a comment
Add your answer
PS15 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 135
