Sony's Xperia Z5 Compact is an Android smartphone featuring a 4.6" IPS LCD display with 720 x 1208 resolution, quad-core Qualcomm Snapdragon 810 processor, and 2 GB RAM. Released in October 2015.
22 Questions View all
Black-ish screen after lcd change
Hi!
I just changed the screen of an Sony Xperia Z5 Compact.
I bought the screen on ebay.
When the screen was changed, the phone startet up an vibrates as it should, but the screen is black. It's not totaly black, because it sends out a super dim light, so it gets a bit brighter, but still its about just black.
I tried to use another moatherboard i bought some time ago, but that did not work either.
So I think it is the screen. But the new screen does not look damaged, and the cabel dose not look damaged either.
I also think the touch works fine, cause i can manage to click buttons to make the phone vibrate, but i don't see what I am doing.
Has anyone had a similar problem? I bought another screen, but if you know something else it could be, then i'm happy to hear it!:)
Thanks!
1 Comment:
Did you disconnect the battery before anything else?
by
Add a comment
1 Answer
Sounds like a faulty connector on the screen, often when the flex cable is not seated correctly in the screen manufacturing process the lcd will display black but the backlight will still turn on. This problem could also be due to the lcd connector not being fully plugged in.
Add a comment
Add your answer
vemundholstad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 865
