The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer door fuse location
Where is fuse on dryer door
2 Comments
Jim Donnelly what fuse are you looking for? what are the issues with your dryer?
by
I don't remember there being a door fuse. Fuses are meant to prevent overloads and the door is just a switch. As old turkey asked, please tell us the problem you are having.
by
Add a comment
Chosen Solution
Jim Donnelly if you are talking about the thermal fuse which is accessible after removing the toe panel, check the tech sheet on the bottom of this page. Page 9 will tell you how to remove the toe panel and page 7 tell you how to test and remove the fuse. The tech sheet will also tell you how to check every component of your dryer etc.
Score 4
Add a comment
If you're asking where and how to replace the fuse which is accessed behind the door on your HE3 follow these steps:
1) UNPLUG power cord from wall!
2) Remove lint screen.
3) Remove 2 screws at bottom of front panel and lift off.
4) Remove 3 screws that hold on the black cover with the warning labels on it.
5) The fuse is right there.
For clear images and instruction see the YouTube video "Kenmore He3 dryer - fuse replacement" by user Quint Jer. You should double check with any markings on your part but I believe the replacement fuse is Whirlpool part #: 3392519
Score 2
Add a comment
Add your answer
Jim Donnelly will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 17
All Time: 5,878
