Repair information for printers made by Canon.
The printer is offline
the printer is offline
1 Comment
Hello Ali,
Can you give a bit more information? What model of printer is it? what operating system are you running?
Thanks,
by
Add a comment
1 Answer
Most Helpful Answer
Your printer will display as "offline" if it can't communicate with your PC. Check to make sure the printer is turned on and connected to the same Wi-Fi network as your PC. To find out if your printer is connected to Wi-Fi, see if your printer's built-in menu has options for checking, or check the printer's manual for specific instructions.
If you're still having trouble printing, try uninstalling and reinstalling your printer driver. Select Start > Settings > Devices > Printers and scanners, then select the printer and select Remove Device. To reinstall it, select Start > Settings > Devices > Printers & scanners. Then select Add a printer or scanner and allow Windows to find nearby printers. Choose the one you want and select Add device.
Score 1
Add a comment
Add your answer
ali hady will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 3
All Time: 231
