A lawn mower made by the American Company Toro
119 Questions View all
How long should a battery last?
I purchased my personal pace Toro lawn mower last summer. The first one I purchased stopped running after 6 weeks. I returned it and got this one. I have had numerous issues trying to keep it running once started but today my husband went to start it and said that the battery appeared bad. Wondering why the battery would be slow to start and then die altogether. I specifically purchased this one as I am the one to mow the lawns usually and I am physically disabled....I need my lawn mower to work for me not against me.
Any suggestions???
Thanks
Add a comment
Most Helpful Answer
Leslie Smith , My neighbors is 4 years old original battery and still working. Charge the battery 24 hrs. initially, then monthly or after 25 starts, is the manuals recommendation, see pg. 16 in the manual( 1st link) for further instruction. If your battery does not seem to hold a charge, the lawn mower carries a 3-year guaranteed-to-start and 2-year full warranty, return for replacement/repair/refund. You should not have issues when running either, perhaps try using a better grade fuel like premium 93 octane with up to 10% ethanol(less is better)and E15 product is((not)) recommended or approved for use in small engines(2nd link has more info.). Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/409301...
https://www.toro.com/fuelfacts/
Score 2
Add a comment
I bought a new walk behind toro, the first time I used it I shut it off went into the house came back out the toro refused to start. Took it back to dealer, he could not fix it. I am stuck with a very bad toro lawn mower also dealer broke the battery box, not under warranty. I paid $110.00 for another dealer to fix. ( do not buy toro mowers)
Add a comment
Add your answer
Leslie Smith will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 43
All Time: 4,067
