The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
SD Card Stuck In Write-Protection (Console Problem)
Hello,
i am having a problem with the console saying the SD card is stuck in write-protection. i can tell you for a fact, the card is not. the slide is at the top and have even tried 2 other SD cards. The other SD cards i have also work fine in another 2DS i have tried.
are there any suggestions how how to fix it? i updated the console and formatted it just to see if that would fix it.
Thanks
Add a comment
1 Answer
Most Helpful Answer
Try to open up and clean the contact pins, they could be dirty and shorting something out.
Score 3
5 Comments:
Thanks for the reply, i gave it a shot but to no prevail. nothing is screaming out at me that there is anything wrong visually
by
What about the 2 smaller pins to the side?
by
they appear to be fine, not touching each other
by
What about cleaning around the connector? Also has it ever been water damaged?
by
yeah ive cleaned it. it was all clean already but gave a clean as best i could just in case. there is no liquid inside. no visible sign of water damage
by
Add a comment
Add your answer
James will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,271
