The Bose SoundTouch 10 is a compact and portable speaker measuring just over 8 inches tall and released in late 2015. It is Wi-Fi and Bluetooth-enabled, and it comes with 2 color options - black and white.
8 Questions View all
Why is my speaker not charging when connected to power?
The speaker is plugged in using the cable that came with the device. The SoundTouch does not appear to be receiving power, and none of the lights will turn on. Can this be fixed?
Score 2
1 Comment
Peut-on avoir le renseignement technique pour suivre / réparer l'alimentation (power supply) du soundTouch 10. Cela suppose sans doute le démontage du boitier.
by
Add a comment
Chosen Solution
This may be because the cable itself has been damaged or frayed. Inspect the cable for any signs of wear.
Also try connecting the charging cable and speaker to a different outlet to ensure that it is either the speaker or the cable that are the problem.
Also check the cable port on the speaker for any dirt or lint that may be trapped inside and preventing power from reaching the speaker.
The port can be cleaned with a compressed air duster if this is the problem.
If all else fails, the charging port itself may be damaged and need replacement.
For more information, see the Troubleshooting Guide.
Score 3
Add a comment
One more thing I. Oticed:
I bought a AC cable that has a 90 degree plug and it didn‘t work as well when I noticed that the plug itself was to short. So try to get a straight plug and push it inside troughly.
Mike
Add a comment
does my ptbt peavy potable speaker has to be turned on off to charge
Add a comment
When I plug My A2 lenrue Bluetooth speaker in to charge, a red light flashes and then nothing else. No lights. I've tried different cords and the UBS wall blocks and different plug ins. Is my speaker done for?
Add a comment
My pathfinder 4 no power it’s been charging for over a day… nothing
Add a comment
Add your answer
James Asbury will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 82
All Time: 8,393
