Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
iPhone 5c screen completely unresponsive
Okay so my iPhone 5c touch started acting up a few weeks back, it would stop working for a few moments, you lock it wait a minute and it would suddenly work again. Fast forward a few days I updated the software and shortly after the touch screen became 100% unresponsive.
I've done all the "reset, restore" instructions I could find and nothing helped, I thought maybe I needed a new screen so I ordered a new display kit online.
It came in today and I very carefully took everything apart and installed the new screen, it powered on perfectly fine, the picture is perfect but the screen is still completely unresponsive!
I've taken it apart again several times to check connections and such and I can't see any reason it shouldn't be working.
Does anyone know how to fix this?!
1 Comment
Is there any way I can confirm that it's a logic board issue that would require that kind of repair without having to bring it in some where?
by
Add a comment
Chosen Solution
The iPhone 5C is prone to all kinds of logic board issues, particularly the loss of touch, caused by micro-fractures. On the iPhone 6Plus, we call this Touch Disease. However, the 5C can also suffer this due to the weaker, plastic housing. The same flexing issues can affect the 5C.
Beyond checking the condition of the connectors on the logic board, I would have to assume that the Touch IC's need to be replaced on your device. This is requires micro-soldering and is not DIY. If you would like to fix your device, you will need to find an experienced repair shop that does micro-soldering repairs.
Score 4
4 Comments:
I've been having a weird issue lately with 5C with touch issues. I found out all of them ended up being caused by the digitizer connector being worn out, damaged or dirty.
It always ends up being the ones that have been repaired before (heaps of times) from another shop, no screen metal plate allowing the screen cables to unplug after the phone gets dropped.
Had this about 3-4 times. Sometimes digitizer connector needs to be replaced.
If the phone is one that has not had screen replaced before the screens will work with no touch issues (when testing with multiple screens to find a working one).
by
Thanks @benjamen50 , interesting observation!
by
by
If the connectors aren't damaged, as @benjamen50 suggests then I would have to assume it is a board problem.
by
Add a comment
i was trying to find the torch mechanism on my phone and sliding finder across bottom of screen Phone went dead and now screen is black and phone is unresponsive i cannot find any sign of life with my phone It was fully charged this morning
Add a comment
Add your answer
misspaperwait will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 9,510
